Originally Posted by mhughett
Is it possible to repair your existing controle module? I thought that companies like this
www.modulemaster.com/
repaired ABS control modules that failed for a fraction of the cost of new parts. I've never had it done myself but I've followed other boards where people have saved a lot of money going that route. TAT is pretty quick too.
Thanks for that link. I did see this before. I would still need the hydro pump replaced as well though. If the code had only indicated the module and not the pump as well, I certainly would think they would be a good solution.
Also, one of the first things the tech said when he was describing my issue was, "well at least you don't have an M6..." It would seem they see a fair number of failures like mine on those and it's even more expensive. Hard to say what real world numbers are on this part failing, but in my search online, this has come up for M3 owners as well.
Anyone else here have this part fail? Hopefully I am an outlier with this problem.
