It can be done. I bought an M-wheel with paddles installed, spent big $$. But if you already have paddles on your Si wheel, I think you can unscrew the paddles from your old wheel. You'll have to drill a hole in the M wheel spokes to mount the paddles. Run the wiring inside the wheel and you should be good to go. Use the back cover from your old wheel. That M-wheel feels great.
