      08-11-2012, 07:21 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Part 3 Coolant Temperature sender install
Temperature install was pretty straight forward.
-step one is to drain the coolant; there a DIY already posted for this...(another maintenance item off the list)
Block drain bolt
The drain bolt is located on the right side directly above the the engine mount & the canister.
(canister pushed up & bracket removed)
It also makes it easier to maneuver with the ground strap removed from the engine mount (blue arrow)
Coolant temperature sender installed
Sender complete with thermal protection
After that just run the wires & button things up.
I brought the wires forward then back behind the heat shield.
