      12-28-2012, 01:15 PM   #71
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
measurement
Originally Posted by XMetal View Post
@drdvac...you can't really measure from the boot since that's not a fixed point. The boot can move up or down as desired. The ZHP knob does sit in the same location as the OE knob at the base, but since it's shorter to begin with, the shifting action is shorter as well.
You misunderstood I think - I laid a straight edge across the top of the console OVER the entire boot and measured from there - up to the top of the knob
The only way that it is the 3/4 of an inch shorter is if there is less space between the top of the transmission shifter shaft and the inside of the top of the knob.
I guess it could fit the hand better but probably wouldn't make the same difference a shorter shift lever would in terms of length of the throw.
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
