Originally Posted by Matt Romanowski
I believe the segmenting feature in GPS Manager is for some of the other dashes, not the SOLO...
... you can do the same process again but segment the track differently and call it a new name (i.e. NHMS 9 segment). When you want to use a different map with the file, just go to Map>Map Manager and select the one you want to use. This will allow you to make one map per track and put it to multiple sessions.
Hope this helps and makes some sense.
Yep, makes a ton of sense. I can have the best of both, just have to flip back and forth between maps. Never would have thought of that! Thanks, Matt.
