      10-31-2017, 01:48 PM   #74
Expert@ApexWheels
Expert@ApexWheels's Avatar
3528
Drives: M3
Originally Posted by pcube View Post
Thanks for the reply. Mine is the 380mm kit. What does a brake template look like, and how do I get one?
Do you know of any ARC-8 specifications that will definitely clear my bbk? Perhaps in 19", which is the size I'm currently running on.
Brake templates are paper cutouts provided by the brake kit manufacturer and are used for test-fitting purposes. They can typically be found on your kit's product page on the manufacturer's website.
The 19" will require the same spacer, since the clearance issue is with the spokes, rather than the barrel.
Hope this helps, let me know if you have any additional questions!
