      09-15-2012, 02:15 PM   #1
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
..::PSI::.. G-POWER Z4M Supercharger System SK I
Since early 2009 we have worked closely with G-Power on their forced induction solutions for BMW. From custom sand-casted aluminum manifolds to laser and CNC cut brackets; their quality is comparable only to BMW OEM pieces.
PSI is proud to offer special introductory pricing on this kit for Bimmerpost members.
G-POWER supercharger system SK I "Sporty Drive"
Basis: S54 Z4M Coupe/Roadster, 333 hp increased to 440 hp
Boost level approx. 5.8-6 PSI.
Components included:
Belt Drive:
Ultra stiff CNC shaped supercharger bracket system made from cast aluminum including an extended support-aggregate belt drive for the superchargerīs drive.
Air Intake Manifold:
Racing air filter and flow optimized clean air intake with large diameters made from cast aluminum.
Forced Induction/Intercooling:
ASA T1 518 supercharger with centrifugal clutch ASA K07 (optional); supercharger lubrication through bypass from motor oil circuit;
air/water recuperator with front mount intercooler; engine inlet manifold made from cast aluminum; pneumatic, load-dependent boost regulation.
Engine Modification:
6 racing spark plugs with modified heat values.
Fuel Management/Electronics:
Adaptation of the software of the standard ECU.
6 x fuel injectors with enlarged mass flow.
Price: $ 9,750.00 w/ FREE installation at our facility in Orlando,FL or FREE shipping to anywhere in the USA.
http://www.precision-sport.com/shop-...e-and-roadster
***We are also currently offering $ 1,000.00 off the above pricing for Bimmerpost members.***
