Originally Posted by RPIpower
The ECUs need to be taken apart. Imagine a busy day (which in most cases is every day), and then an engineer has to stop, take apart the ECU and then program it. Its not as easy as plugging something into the actual ECU and then uploading a program into it. There is an actual set up process.
The one time free reflash is something that I am working on right now.
I guess I had to ask. Will you be offering a tune for the 3.0SI? Only reason I asked is because when I spoke to Dinan, they were doing the software for the M and said the ecu for the SI is very simaler. I would be interested in this as well.Thanks
