      07-07-2012, 02:25 PM   #5
PrinceMiro
PrinceMiro's Avatar
Drives: z4 3.0i
Originally Posted by aerobod View Post
The eccentric bolt/washer on each side are items 10 and 11. They are rotated to adjust the camber (which should be done before the toe-in). 3 bolts on each side marked item 19 are loosened and plate 17 is moved to adjust toe-in.
Thanks a lot!!
Originally Posted by BruceJ View Post
Since you posted drawing of the rear Im guessing he at least told you the problem is with the rear setup.
Ask if the rear trailing arm bushings (#4 in your pic) are worn out (RTABs). This is the most likely culprit. If so they have to be replaced.
If you have some mech ability and the proper tools (Search DIY RTAB here or on the E46 Fanatic forum) this is not impossible to do yourself - but if not... its gotta get done.
http://www.zpost.com/forums/showthread.php?t=673800
Unless you track or just want the car much tighter (and rougher) I'd go with a rubber bushing
Parts:
ECS : http://www.ecstuning.com/BMW-Z4-3.0i...g_Arm/ES57714/
or
http://www.vorshlag.com/product_info...products_id=59
Good Luck
I don't track but I do want the car much tighter. I'll be changing the struts and springs soon. So, I'll probably get the RE RTAB's.
Originally Posted by seank View Post
Can you give us more information on what he told you, what alignment you received and the miles on the chassis?
Sure. I just had a regular 4 wheel alignment because I just went from a 17" square setup to an 18" staggered setup with a different offset and tire size in the rear. Passenger side rear tire had one tread barely off the ground. Driver's side had all treads evenly on the ground. 72k miles on the chassis. It's a 10 year old car (Sept 2002 production). I figure the rubber bushings are starting to go. I've already had to change the FCA's, FCAB's, and FSM's because the rubber in those parts had deteriorated pretty badly.
