      09-14-2012, 08:58 AM   #24
Beedub
e85 //M
kw clubsport, including Kw uniball camber plates
400lb linear fronts progressive rear spring with end rate of 700lbs (according to kw)
stock sway bars
(additions)
turner rtab limiters
front strut brace
poly bushed RE reinforced top mounts (rear)
Camber shims installed, camber set to -2.7
settings are 6 clicks front rear 12 clicks on rebound, bump is 0.75 on each axle.
