Originally Posted by TSM330i
We are going to run BFG R1 in 265/35-18 square on our e86 3.0si race car. If I were you, I'd put the widest tire I can fit on the car. Running a square setup will allow you to swap tires to even out wear as well and help with longevity.
What width wheels and offset? How much negative camber up front? I assume you'd need camber plates to fit the 265s up front.
