Originally Posted by Finnegan
I assume you have Euro headers. If so, Supersprint X-Pipe and Race Cans are pretty much as loud as RPI. Look at the OP: the RPI only set up compares at just a bit lower sound pressure level than the SS setup. The pitch/tone of the SS is lower though, drone is a bit less. SS Powerloop might be a better choice. Or, Remus sport (or Eisenmann sport if you can find used) + Rogue Xpipe. (Rogue xpipe seems to provide more bang--pops burbles--than the SS Xpipe.).
Depends what you're after. Remus and Eisennman do not drone, neither does Stromung or SS Powerloop. Pair those with a Rogue Xpipe and it's a good match.
Thanks for the info mate.
I did check the first post but exhaust tone and drone are very subjective things and thought it's worth it to ask for a real opinion. How do the setups you mention compare with rasp though?
