can you post your pm msg here for all to see?
anyways our keys do not charge when they are on the ignition the only thing that it does is activate the signal, if you don't use a key for long time it will hibernate to save battery. so when you go to use you will need a minute or two to wake the key up.
everything sounds good with my diagram but is coming with a price tag too hi at the moment so I'm trying to work on getting it to cost less but not sacrifice quality maybe re-disgn, also is hard to have access to components here, the link that you gave me is very good I will take a look on it later today to see all they got.
Okay this are the main points of the project:
1 turn ign on and start
2 turn ign off w/o starter being activated
My plan is to get a momentary pulse and switch to constant to keep ign on with the first push of the button
