VT said the the OEM transmission mounts are a better design than the RE transmission mounts. As far as your motor mount bolts are concerned, I think that the original grade of bolt will work fine.
Here is a thread talking about it.
If you get other ones, two of them are longer than the rest. But I would just make sure your original bolts are tight.
