Do you hear that click near the pedals (like its in the footwell, and in the cabin) or more in the middle of the car around the ashtray.
You can also listen if a friend is operating the clutch that if its more loud in the cabin than under the car.
Its either a problem with your pedal/input cylinder or a problem with your slave cylinder/clutch fork/pressure plate
