Originally Posted by elerner61
Exactly! Don't let those rev's drop too much. I'll also add that using a faster gear shift movement works better for me too. Just because the rev's aren't high doesn't mean you can't shift quickly.
I agree
Shift faster = Smoother shifting
Anyone else find that you can shift faster by moving the shifter gently trough the right path. whereas Pulling the shifter hard just causes it to grind more and delay your shift?
