Originally Posted by Shipkiller
Frank,
I left foot brake, and trail brake....
No problemo with trail braking, as that's still just one pedal at a time.
When you left-foot brake, are you actually applying the brakes and throttle at the same time, or doing it to minimize transition time between brakes and throttle but not applying both simultaneously. If the latter, then it'll still work fine. If the former, the math channel will return the net value of throttle and brakes at that moment, which'll be pretty meaningless.
