      12-10-2010, 01:15 PM   #3
Pheonix
2007 BMW/Z4MC  [0.00]
I don't have information on the alignment specs. However, i know tires wear will be significantly worse! Basically, i purchased a set of used wheels/tires with less than 5k miles on them. The previous owner has H&R Spring installed and did not do the alignment. The inners of Rear tires were down to less than 1mm vs. the outters of over 5mm (i believe the tires were 10/32" or 7.94mm new)
