      06-06-2012, 03:14 PM   #3
3002 tii
3002 tii's Avatar
2285
Originally Posted by Erhan View Post
Are those track pads? The reason for the squeal is that track pads have metal in them, so as your rotor. Metal on metal = squeal, unless you bed them in. But the problem is, even if you do proper bed-in, since the track pads are very abrasive at cold, they will remove all the pad deposit from the rotors, and you'll have metal on metal issue again.
ps: Sorry if I am stating the obvious.
Ha, yes I'm aware that track pads squeal. My 06's have always been squeaky but only when I apply pressure on the brakes. But last time around, even when I was NOT on the brakes, just coasting... it would squeal, and far louder than normal.
Follow for latest mods
