Park against a wall and see if the steps in the cutoff are at the same level. Looking at the car from the front, and kneeling down the cutoff should show up first in the drivers side headlight. Auto leveling calibrates the projector itself, it doesn't re-align the projector. You have to manually adjust them with a hex key after lowering. Takes 5 minutes
instagram: @ dubsesd
