Originally Posted by F360C
Although I really like the oem brace, the reason I always wanted this brace is due the cracking issues I have read about when the oem brace is on a hard driven car. Due to the oem brace's base plates being a cast part they simply do not have the same material strength at the RE brace. If you search the Bimmer forums track section or m3 forum you can find multiple instances of this happening.
Good info. I did not know that
