Ive searched the other threads of of similar issues but I think mine might be a little different.
I intermittently get a YELLOW ABS light, a RED HAND BRAKE LIGHT, a YELLOW TPMS LIGHT and a YELLOW TRACTION CONTROL LIGHT.
All lights come on at exactly the same time, usually at around 3-3500 RPM. When they come on, I can notice a very slight drop in power and my radio cuts out but does not shut off, just no sound, time still shows.
I had one mechanic run obd to see what codes popped up, he got some voltage warning codes but he couldn't confirm exactly what it was.
Having read the other forums, im starting to think its either the voltage regulator, or the whole entire alternator.
Im also gathering that it could be a wheel speed sensor or a dsc module, or a abs monitor, or the MAF sensor?
if somebody can help me out, id be very very thankful!
