Originally Posted by Finnegan
Vorshlag are a bolt through design with 80 durometer poly right? How's the NVH with those? Did you go with the Vorshlag motor mounts too? (Lots on their website about motor and transmission movement leading to a denial of gears on downshifts with stock BMW mounts.)
Yup, using the Vorshlag red motor mounts (had UUC motor and transmission mounts before but much happier with these). NVH is considerable - radio is almost pointless
I noticed a big improvement especially at one of the tighter corners on the track where I used to have trouble gettting into second gear.
