Originally Posted by unluky
OK - gathering all my parts for my H&R/Blistein install. I am "that" guy that if I am taking something off - I will look at replacing it at the same time. I bought all new spring pads, Front bump stops, upper strut mounts, rear shock reinforcements, and rear shock mounts.
My car has 75K on it, but has always felt tight and very solid, but hey - I plan to have it awhile and while I am in there.....
Anything else I should look at? How common are front sway bar links for replacement? For $60 I am considering putting them in while I am in there - unless that is just stupid?
Already did FCAB's and sway bushings last year.
Want to tackle everything while I am in there!
LOL, I asked my shop to do the same thing. I just needed one broken rear spring replaced, but $1700 later I got new:
Eibach Pro-Kit lowering springs
Koni sport shocks
Rogue Engineering RSM
Meyle FCAB
Front strut mounts
Front upper & lower spring pads
Front bump stops
Front dust boots
Rear upper & lower spring pads
Rear bump stops
Rear dust boots
Do some research on the different sized spring pads - I think we have the option of going 2.5mm, 5mm, 10mm, or 15mm. My kit advertised a 1.2" drop all around, but my rear is now 1/2" lower than my front. You may want to put in a slighter thicker rear spring pad (10mm instead of 5mm) so it looks more even after the installation is done.
