Originally Posted by Z4Murder
bump
I think so. Some have run a 265 front with stock suspension on a 9.5 wheel with 9.5 ET35 wheel with 5M spacer (that's a 30 offset). A 9 ET31 has more 5mm more space to the strut and 7mm more from the fender. YMMD depending on type of tire (square or rounded sidewall) used, camber settings, and so on. Rear is no problem.
Have
a look for yourself and do the calculations. Don't count on me only!
