I don't have any clutch issues, and neither does anyone else with this kit on this forum. You probably have a little more torque than us, but a stock clutch that has been used without abuse should still be able to handle things . Use the opportunity to upgrade to a stronger clutch AND a lightweight flywheel. I haven't researched the options yet, so I can't make reccomendations
I was also considering upgrading my diff, but it will make traction even worse in 1st gear
