      07-27-2013, 09:12 PM   #905
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Originally Posted by Z4MHawk View Post
Guys,
How many of you with the VT1 or VT2 have modified your air intake so that you don't have to remove the front grill and nose assembly to replace the cone filter? I think I saw a post from one of the inmates with a new VT2 setup that had enlarged the who thru the front radiator/frame brace so that the filter and flex hose could be pulled back into the engine compartment.
On a second note, my intake pressure hasn't chnaged since I had my VT1 installed by Goodspeed. Anyone have in hard rules about replacing your filter cone or is it by visual inspection?
I haven't modded that area, but I'm due for a filter wash. I'm also thinking about putting some heat reflective tape on the intake piping, but first I need to figure out how to isolate the hot engine bay air from the air filter.
On another note, I've been running a non-Ess approved main belt for a few months, and apparently its slipping. I took her to the quarter mile track last night, and was only trapping 107MPH, 13.2 was the best run. weak weak weak.
My meth kit's pump is dead, so I'm gonna replace that, and get a new belt.
Then its time for catless exhaust finally, and to start saving up for big-boy mods
