1 x 11-12-7-832-034 profile-gasket valve cover gskt
13 x 11-12-7-830-972 rubber seal valve cover bolt gskt
2 x 11-12-1-437-395 rubber seal valve cover bolt gskt
6 x 11-12-7-831-271 profile-gasket spark plug tube seals
2 x 07-11-9-963-129 gasket ring zinc crush washers
the vanos gasket is PN 11-36-7-831-938. there is absolutely no way that the cam bolts were checked if the vanos wasn't removed. that gasket is one-time use, so if they did check the bolts, they should have replaced it.
#1498 E86 | Sepang Bronze | Dark Sepang Leather | Carbon Leather Trim
