      06-08-2012, 01:36 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Originally Posted by nwflbimmer View Post
I have searched the forum looking for instructions concerning this. The most recent comments are about a year ago and I am not sure the people are still on the forum. So I am going to just ask out right and confirm what I have interpid.
The hood sensor seem to be pretty cut and dry. It mounts between the two cross members on the fire wall under the hood. the wire looks to be behind the brake reservoir.
The siren/tilt snsor is mounted behind the passenger rear wheel. Asd I understand you remove three (3) plastic screews and pull back the plastic wheel liner. I looks like it is mounted next to the carbon canister. and the wires are just loosely hung there.
Once everything is installed you go to the dealer to have the alarm coded, before it works.
Thank You
Paul
All correct, with the exception of the location for the alarm unit. Goes more or less between the two mufflers. Here are the instructions I used.
