      03-06-2013, 01:48 PM   #12
elwesso
elwesso's Avatar
25
Drives: Z4 M Coupe
Originally Posted by Shipkiller View Post
If you are going to do this yourself, then:
A dolly is specifically NOT recommended by BMW and is stated "use at your own risk and possible damage to the vehicle may result".
If using a car carrier, do NOT attempt to tie down the car using the wheels. The approved and accepted method is to use four T-Hooks. You pull the four plastic jackpads off (they are designed to come off) and insert the T-Hooks.
I keep two T-Hooks in the car at all times for emergencies.
Good info, is there any way you could elaborate on this, or what I might search to find this out?
- Wes
2007 BMW M Coupe
2016 VW GTI
