Originally Posted by bassrebel
I'm planning on getting 18x8.5 in the front and 18x10 in the rear...
tires up front are 225/40/18 and rears are 265/35/18
what would the recommended offset be for a setup like this?
I have stock suspension for now
for 8.5" up front you'll want between et40 and et35
the only offset that will work for 10" in back is et40, and you'll need a serious amount of camber. you'll also need a fat stack of cash for all of the tires you're going to go through because of wacky alignment.
