Cross posted from the California region board:
The one day format in June worked so well, the L.A. chapter has secured another date at Auto Club Speedway in September for local enthusiast and members alike.
Event info and registration is here.
Price of entry is a reasonable $225 before the August 20th deadline. I believe it's $250 after.
A couple of house-keeping notes, if you've been to one of our driving schools before, you will need to be a BMW CCA member to continue to attend our driving schools. If it's your first time, we're like crack dealers...First hit is "free". Also if you sign-up to BMW CCA using the following membership number as your referral, 182861, you (and I) will be entered into the drawing for an ///M Performance School at the Spartanburg facility.
We've also secured the use of the parking lot outside the course (not the auto-cross lots, if you're familiar with AX as well) to be used for wet skid-pad exercises as well. In addition to your 4 regular run groups, you will also get the opportunity to sharpen your car handling skills on the wet skid-pad. THIS IS A GREAT OPPORTUNITY! Turn DSC off and go have some fun with little repercussions besides a dirty car.
If you're not familiar with the infield layout, it is literally a different track, or will feel like it, if you've only driven the Roval. It's short, compact, and relatively technical compared to the Roval. The back side of the track where you re-enter onto the Roval splits to the right and there's some combination, multi-apex turns and spits you back where turn "5" used to be for the Roval. It's a fun configuration and great layout for learning, because unlike the Roval where it'll take you 2 minutes plus change to complete, and with the way CCA sets up the chicanes you will likely only get 8 laps out of a full 25 minute session, the infield you can easily get
12-15 laps in that same span of time. Meaning it's a great opportunity to fine-tune and correct your lines and master the course. And there's still some very high speed sections between the decreasing radius 180º turn affectionately known as the "tip of the phallus."
Take a monday off and spend it having fun rather than in front of a desk working!
