Originally Posted by Chuck I
I thought about this all day... got home, removed the ashtray and button panel. I didn't see any cable. I then unsecured the gear lever cover and moved it to the side... I then started feeling the cables and noticed that the one on the left had two ends... one went to the gear shift lever and the other went under the carpet... I took a hook and pulled the carpet up next to the gear shift lever.... GUESS WHAT... There it was the connector for the sport button... My button is on order... when it comes in, I'm just going to plug it in and see what happens... I then have to cut the hole, but that's easy enough... I'll keep you posted... so far, this has taken about 15 minutes... Chuck I
Very interesting. As far as cutting the hole, I think the console is perforated underneath and just needs to be punched out.
