Originally Posted by Chuck I
It's a 6 pin connector with 5 wires.
Pin 1 Brown/Black
Pin 2 Slate (gray)/Red
Pin 3 Black/Slate (gray)
Pin 4 Green/Blue
Pin 5 Black/Yellow
Pin 6 Empty
I had a hard time seeing these because of the fact they are wrapped really tight and the lighting was not that good... The Slate (gray) may actually be white...
Hope this helps... Chuck I
Pin 1 is BR/SW Brown/Black = Ground
Pin 2 is GR/RT Gray/Red = Dimmed lighting
Pin 3 is SW/GR/GE Black/Gray/Yellow = Power steering
Pin 4 is GN/BL/GE Green//Blue/Yellow = Power, fuse 7
Pin 5 is SW/RT/GE Black/Red/Yellow = To DME via module (VM)
Not sure this WDS print goes with your '03 car.
