Originally Posted by Rated M Roadster
The benefit of air to water intercooling is pretty apparent in the higher boost levels; the ESS kit looses boost through all the air to air intercooler piping. G-power uses the same type of air to water (via extra radiator at the front) system as VF. The reason air to water is actually better is because you don't loose boost while still getting cooling. Alternatively, you could do air to air and lose boost, but get better cooling; I'll take the higher boost.
you are going to have the vf kit installed soon, am i mistaken?
