Originally Posted by RossBMWZseries
Makes sense, very helpful. I'll give this a try as i'm currently needed a lot of parts
Sometimes its a bit easier to find things on bmwfans.info. The parts diagrams used are the same between the two sites, but they're bit larger on bmwfans.info. Also, some things you'd think would be body parts BMW considers trim so if you don't see it under bodywork, look under Vehicle Trim. The other tip is that parts aren't always shown attached to other parts and they may be in the diagram in an orientation different than what they are when installed.
You can also do word searches as The Hack suggested using FCP as the prefix. That will get you options from FCP Euro, also a good parts source.
http://bmwfans.info/parts-catalog/E8...ounting_parts/
https://www.fcpeuro.com/products?key...hood%20support
