      01-21-2013, 05:36 PM   #4
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
RS3s have 255, and probably Star Specs. EDIT: Just saw you run 19s.
You get to the point where you get different slip angles, sure...the tires heat up differently weather it be inside tire, outside tire...front/rear.
But, if you get different tire, now you play with different sidewall deflections and slip angles. For example, RS3s require huge amounts of slip angle to get maximum grip, where as the Star Specs do not. With this, you will not satisfy the front w/out disrupting the rear...and vice versus
