      03-16-2013, 01:34 PM   #397
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Originally Posted by tikamak View Post
You also need the uncorrected data.
Why are you set on the uncorrected data? There's a reason the SAE (Society of Automotive Engineers) corrected values are the standard. Uncorrected data is just what the dyno decided the car made, and a car in a hot Texas summer will read much lower than the same car in a cold Canadian winter. SAE corrected numbers allow for some element of standardization, because the corrected numbers should be similar in either of the above cases.
http://en.wikipedia.org/wiki/SAE_International
