Originally Posted by 3002 Tii
Originally Posted by pal
Be extremely careful if you do that as you can crack the paint. Also watch how the fender liner rests on the lip.
My body shop recommended against rolling or cutting the fender so they pulled it out just a tiny bit to give me the extra clearance for wider tires.
Bump, which shop did you go to and did you work just rears or fronts too?
Ultimate collision in Edison, NJ; speak with Gerry the owner.
