Originally Posted by GomboRombo
So what had to be done that is not bolt on and go? Did you install the kit yourself? Did it come with good documentation for the install?
I would appreciate any opinions anyone has on the installation. I have installed turbo kits on other vehicles before and the only scary part I ever had to do was drill and tap the oil pan for the oil return.
Sometimes they send wrong parts and you find out the wrong way in mid installation, sometimes you need to drill out some areas in your engine bay for a better fit.
Fairly easy things and the installation is not very hard, a little hard when doing the intercooler pipes on the ESS kit because of the crammed up space.
