      03-07-2019, 01:40 PM   #20
jhall1957
Drives: SE 46
Originally Posted by Azeka1 View Post
Originally Posted by jhall1957 View Post
So you were able to install all this and not remove the big black plastic part behind the seats? My stock seats are right on those speakers behind them. Maybe the fixed back seats are a bit less bulky.
That is right, all interior panels can be reinstalled and even the center console works as intended.
Unfortunately I have not tested the OEM seats. Considering you are right up on the rear bulkhead panels, any harness bar setup sounds like it will force you to move a little forward.
The roll bar can be ordered without the harness-bar though if you perhaps want to mount your harnesses using eye bolts fastened through the bulkhead.
I'll be adding fixed back seats.
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
