Originally Posted by Beedub
good point, car hasn't had a knock at any point has it?? this is not a common issue you see on the z4s but inline with the mashed camber pin hole / paint cracking in diff areas it appears to me the area has been subject to some stress....
No hits, car is accident free. Original fenders, bumpers, etc. Both camber pins were pulled by myself to dial in negative camber when I started doing autocross, that hole was a-ok prior to this last alignment as far as I am aware. The nuts were never loose either, typically torqued to spec every few events. I'm pretty confident it was a lazy tech that did it
