Originally Posted by Finnegan
The clutch itself, on engagement, should feel smoother and better if the old one was worn or out of spec. Nice and smooth--"like butter"--man, just a bit of hyperbole huh?
Does the clutch engagement point move, or is the pedal just feel slightly softer? Try this: put the car in gear (safe location like a open parking lot), depress the clutch just past the engagement point, hold it there 30-60 seconds. I would suspect if there were air in the line the engagement point would "slip" and the clutch would begin to engage. (That would be akin to a soft brake pedal where the air compresses and the pedal moves/is soft--fluid doesn't compress, so the engagement point should stay stable). If the engagement point is stable the dealer might not be off base. Anyone else have input on this?
I'm sure you know this as well, but a new clutch and new transmission have a break-in period. Clutch takes 300-400 miles IIRC, and you want to be easy on it and the transmission during break in (keep the revs down and don't use full throttle). Read the manual on that. It's 1,200 miles on the transmission IIRC, and at the end of that the lubricant should be changed. (Typical M break-in requires all fluids, engine, transmission, diff to be changed out at 1,200--since just the transmission is new, service s/b done at 1,200.)
Thanks for the input and tip Finnegan. The engagement on the new clutch does feel better and smoother. I don't think the engagement point actually moves, the pedal just feels softer and lighter than before. I remember picking up the car at the dealership after the clutch and transmission replacement, when I depressed the clutch to start the car that my foot suddenly went all the way down to the floor cuz I wasn't expecting the clutch to be that soft and light. I would like to try your tip on the clutch however my car is at the dealer again!
The car died on the freeway this morning on my way to work. It first lost power when I was in 6th gear then it started sputtering when I tried to give it more gas. I then clutched to downshift and the rpm dropped all the way down and then the car died. I couldn't start it back up so I had to get it towed. The shitty thing is that my warranty expired at midnight on 10/4 and today is 10/5 FML!! My service advisor said he'll try to take care of it but he has to find out what's wrong with it first. I'm guessing it's either the coil pack or water might have gotten in the engine somehow. Keep in mind that today was the first day this year we had hard rain in socal. It was a very shitty day for me today.
I'm keeping my fingers crossed that they can fix my car under warranty. Wish me luck!!
