Originally Posted by Jackal
Harnesses that go upward as they gain distance from the shoulders do allow a little movement of the shoulders upward. This is largely mitigated by the tension placed on the main buckle by the side belts, and if you use a 5th point it helps to prevent this upward movement as well.
Still would love to see some detail on the mounting in the B-pillar as well, but I realize this can be a pain once it's all put back together.
This, plus if you're using a HANS it's not secured as well.
