Thread: Antenna
      08-21-2011, 07:18 PM   #130
sabbanick
Drives: 08 SBM M coupe
Originally Posted by Uncle Russ View Post
Ok, my antenna and base were corroded together. Despite the PB Blaster I sprayed on the seized pin, I could not get it to release and ended up shearing it off. I drilled it out and tried to remove its remains with an extractor (after more PB) and all it did was spin the base. I'm now going to order a replacement base & grommet to get this thing finished. Is there just the one retaining nut at the base of the amplifier module that holds everything together?
yes, but you have to remove the interior trunk trim panels to get to it.
