      03-23-2016, 11:49 AM   #7
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Bad coil and misfires? I'm not sure if there such a thing as a lazy coil, but you could certainly get some vibration with a semi-functioning coil, corroded plug, moisture,etc.
I know it's going to sound typical, but if you tried using a BMW code reader or knock off (eBay)? There might be some fault codes that you could read, and most of these allow you to read data in real-time which allow you to get a better glimpse of what's going on with the engine.
