Originally Posted by David70
I would assume they would want to see where all the interference is and try to do better on the 2nd go around? Seems like you make it fit with hammering the areas down and then send it back to them and they have good idea what needs to change on the 2nd one?
Maybe this would work with pictures but might be difficult.
Even if they redesign thr collector, it doesn't clear or even have room for the oil return pipe. Only way to make it fit properly would be to completely redesign the header and cut off a section of the one peice flange rack. I obviously will be working with them to see if they will do it. But my priority now is getting a way with the oil return pipe and make it safe for the car IF possible. Also see how it does completely mounted.
