Switching to non run-flat tires?
What are the pros and cons of switiching from the run-flat tires on a 2003 Z4? Is it possible? Is it adviseable? I have heard that non run-flat tires provide a softer ride and last longer. BUT . . . what happens if you get a flat or blow-out and you have non run-flat tires? Is there even a way to jack-up the Z4? Thanks for insights and info.
