      10-13-2012, 07:49 PM   #9
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Originally Posted by JeffchaPz View Post
Hello my NJ friends.... I made sure to label the front and rear sensor with blue tape before removing them the first time so I'm sure they were not mixed or anything like that.
I just checked and changed the gasket between the engine and the header on bank 1.... I started the car for few mins but the SES still there. I haven't gone out for a drive to see if it goes away - but if it doesn't I might two suspects in mind 1. the air filter orange outer layer/gasket was pinched and it might be letting air from the side. 2 I forgot to check for the freaken fuse... I know there are fuses for the O2 sensors.... just don't know which fuse(s) to look for.
Anyone knows where the fuse(s) for bank1 Sensor 2 is ???
Jeff I am no pro but I would assume if anything is flipped you would get 2 errors. Is your o2 wire intact? My gut feeling including my own issue the fact that my o2 is cut into.
The Raspinator
