      01-01-2013, 07:13 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
What color was the smoke? Black? If so, that would indicate a rich condition, not clogged fuel lines or a bad fuel pump. Possible causes might be a bad MAF, TPS (throttle position sensor), or some other sensor.
Best bet would be to run a scan on the car for codes and see what that tells you about the problem.
